Making an axle
lckstckn2smknbrls
I have the spindles from an bent axle I replaced under my utility trailer. I'd like to use them to make an axle for a small boat trailer. What type of round pipe do I need? Black pipe, galvanized pipe, heavy wall electrical conduit?
oldjeep
Re: Making an axle
HREW or DOM. Wall thickness will depend on the load you are trying to carry, but I wouldn't go lighter than 3/16 in any situation.
lckstckn2smknbrls
Re: Making an axle
If I use 1/4" wall thickness I'll get 1-3/4" OD axle. If I use 3/8" wall thickness I'll get 2" axle.
minuteman62-64
Re: Making an axle
My Dilly uses a 1 1/2" X 1 1/2" "U" shape, 1/4" thick. With the "U" upside down there's no issue with water entrapment and resulting internal corrosion.
Don't know how heavy your load would be, but mine carries about 800 lbs. of boat & equipment.
lckstckn2smknbrls
Re: Making an axle
That's the style axle of the axle I want to replace and the style of the axle I'm getting the 1" spindles from. The issue with the axle under the boat trailer is the spindles are 3/4". The new axle tube will be around 42" long. My duck boat / jon boat is 700 lbs.
lckstckn2smknbrls
Re: Making an axle
It is easier and cheaper to buy a New axle with spindles.
I have the spindles, hubs, bearings and a nephew in high school that does my welding. A 48" piece of steel and spring perches is all I have to pay for.
