PikeHunter431
Thread starter- Joined
- Sep 8, 2015
- 171
No Title
May 25th:
Installed the finished section of flooring under the consols. I installed the floor sections with some coated deck screws I had. The thought is I will be removing them when I finish the rebuild later this summer and the screws are easy to remove. I also believe that after I clean and Gluv-it the hull, I can put the foam back in and place the floors back in with the screws. The holes should be reasonably easy to align back up. My hope is to then take the screws out one by one and replace with rivets. The holes should be aligned and sightly larger than the screw holes. We will see how that works.
I finished putting foam in the bow section and made a temporary floor piece for the bow. The electric motor is a 24V system. I am placing a battery on each side to balance the weight. This required us to run a wire under the floor to connect the two batteries.
I forgot to put the aluminum cross slat in on the front of the section which goes under the consols. When I screwed the front of it down, the floor sagged a bit in the center. This oversight seemed to work out for now as the consols were then not jacked up too far out of place. I have been replacing the 3/8th plywood previously in the boat with 23/32nds. I like things on the solid side. I will have to move the side mounts up on the consols when I rebuild this summer. In the last picture, if you look at the bottom, you can see the difference in the floor height. The net result was the windshield wasn't too far off to use for a couple weeks. When I go up for the second week, I am going to put some weather stripping on the sides so the middle section doesn't hang on the hinge all the time.
May 25th:
