Manifold leak
bcontento
I have a 1972 Evinrude 40 hp (a bunch of you just helped get my no start issue resolved). Got it running and now there is a bit of a manifold leak here. Is there an easy fix without pulling the entire front off?
I can see a little vapor of some kind puffing out there and every little while I get a pretty good burst out of that spot. Kind of like a backfire.
Remove starter.-----Remove carburetor.----Remove reed valve plate.----Inspect reed valves.----Replace the 2 gaskets.----Re-assemble.
bcontento
did you try to torque down the bolts at least ..
Yes that was of course the first thing I tried. They were loose. They're old crappy screws. I'm thinking of taking them out and replacing them with bolts that I can put a little more torque on.
They made thousands of these motors.----No need for better screws at all.----Replace the gaskets.
bcontento
Unless of course the Flathead screws are 50 years old and putting a screwdriver on them well is virtually impossible.
