Manifold Question
mfd2698
I have a Yamaha stern drive with a GM 3.0 L4 engine, I am getting water in the oil and on the plugs. I replaced the head gasket and manifolg gasket this weekend and still have t he problem. Pulled the plugs out, cranked the engine and water shot out of all four cylinders. I am thinking the manifold is cracked but as everyone knows Yamaha does not make the manifold anymore. I think I found a match with a Mercruiser, my question is will the Mercruiser manifold work?
Any help will be greatly appreciated, I have been wworking on this for over a year and think this will be the final fix.
Thanks
Re: Manifold Question
Ayuh,... Try it, 'n come back 'n tell Us how it works out...
ricovw
I think it would probably work. It is the same block that mercruiser used in that same era. Its just making everything else that goes on work. Like carb and riser.
mfd2698
Thanks... If the carb I have does not fit can I use a merc carb?
ricovw
i would think so, but there are guys on this forum that may know better. It is the same motor, just marinized by different companies like mercruiser or yamaha.
