Manifolds
GasCan II
I am changing the cast iron exhast manifolds and risers to aluminum,they came with s/s bolts for the risers but none for the exhaust manifolds.
The question is do I use the same steel bolts over or do I buy new s/s ones ?
Almost forgot its a 5.7L 350c.i. Mercruiser.
Thanks !
Re: Manifolds
Thanks !
Ayuh,... SSteel is unnecessary, but whatever trips yer trigger is just fine...
achris
More fish than mountain goat
Re: Manifolds
Thanks !
I'm with Bond-o...
If the water gets that high in the boat, then you have bigger problems than whether the bolts will rust... :D
littlebookworm
Re: Manifolds
Just throw a little anti-seize on the threads and you'll be good to go. Retighten the bolts after a few hous' run. Aluminum manifolds on a steel block can have some leakage problems due to the different coefficients of expansion of the two metals. Just check it regularly for signs of leakage. Hy
