vsokolofsky
- Joined
- Aug 11, 2015
- 3
I just purchase a pontoon with a 1992 70 HP 2 stroke with oil injection. Motor runs great but having problems with the manual tilt. It has a hydraulic cylinder to assist tilting the motor up and down but having problems getting it back up. Motor had been sitting for awhile but cable does move about a 1/4 inch and appears to be in good shape otherwise. Initially had problems getting it down but lubing the cable and fiddling with the handle eventually we got it to go down. Had same issues getting the motor up but with more lube and more jockeying with the handle, we got it back up. Thinking we just needed to keep working it and lubing the cable, we lowered it again but now can't get the motor up again. We're thinking there may be a problem with the handle because as I mentioned before, the cable only moves about a 1/4 inch. Is that amount of movement normal or should it be more? Have never had an outboard with manual tilt before so this is all pretty new to me. Also wondering, if the handle is the problem, what do I have to take off to tilt the motor up to take that handle off and see if that is indeed the problem? Sure would like to get her in the water this weekend so any help is appreciated.
