Manual tilt settings
JRegier
Hey guys, I was wondering about the pin position for my manual tilt on my 115hp motor.
My friend says that if I put the pin closer to the transom that the motor will push the bow higher while running but I think it will push the bow down into the water more.
Which is it?
Daviet
Re: Manual tilt settings
You are correct, the further under the boat you angle the lower unit, the more the bow goes down.
