Manuals
Sirrobin53
What do I need to be able to get the manual download for the Mercury 75 elpto 1B065874 USA built outboard? Even when and if I find that link, it says that I am not authorized to look at it. I have the rough running shake pop at idle. Trying to find the regulator /rectifier.
Sirrobin53
Found it. Is this a pay per view? Or is my membership enough?
Sirrobin53
This 75 Mercury is my first Black motor. Came on a pontoon that was the floor plan I was looking for that I purchased. Runs horrible. Need a SM to try troubleshooting.
GA_Boater
You saved a link to a closed and deleted topic;
deletedtopic.PNG It was closed and deleted because the links are bad as you found out. The following is on top of the Merc FAQ page because iBoats does not own or maintain any of the links. Any external links are only a public service for as long as they last.
[h=2]FAQ For Mercury/Mariner Outboards[/h] February 17th, 2011, 08:54 AM
Disclaimer
iBoats has no control over external links contained in stickies and to be aware that links are fluid and may or may not work.
Sirrobin53
That explains it. Many thanks for the help with this. I am grateful for your help and I support the forum. I hope that I will be as valuable to this forum as those that have helped me are.
GA_Boater
Use the Boatinfo link that Scott posted above. It's working for the time being.
Sirrobin53
Must be something about my phone. No functioning slider on the page.
jbcurt00
Look directly under the image of outboard manuals. Theres a thin black line that has a small gray slider at the far left end of it when viewed w my Samsung S8.....
its hard to see, even harder to manipulate, but by zooming in a little, I can use it to navigate thru additional years/models.
Click image for larger version  Name:	20181225_214038.jpg Views:	1 Size:	325.9 KB ID:	10690593
jbcurt00
Actually it works even better to zoom in and tap the black line about 1/2way across the screen. That makes the slider jump to the position you tap.... then you can guage where to tap left or right of the new slider position to move along to the manual you're looking for
its a java heavy web page, many phones are not java enabled. use the phone to call, and the 'puter for looking at the manual.
Sirrobin53
Success. :yo:. Although temporarily. Now I have to find my laptop. My phone doesn't support adobe. :noidea:​​​​
Sirrobin53
jbcurt00. 1 picture (and arrows) worth 1,000 words. Thanks.
Also, thanks to the others. Everyone explained the same thing. Just hard for a numbskull like me to cypher.:lalala:
. I FOUND MY SMILING. That's ME! I'm always somewhere out in La La land........
