I just got a 16' Alum. boat made by Cherokee - with a 50HP Outboard Mercury 500 engine that says Thunderbolt Ignition on it (serial number = 3482072). My questions are:<br />1) On the MerControl there are two levers. The larger is the Forward / Nuetral / Reverse lever, and controls the throttle. The other effects the throttle as well, but does it play any other role?<br />2) I ran the battery down and had to be jumped. This could have been caused by idling the engine for a proloned period, and/or using a trolling motor intermittently. In either case, what is the charging capacity of the motor and how is it accomplished (unlike a car, there is no generator or alternator). Is charging effected by engine speed?<br />3) What mix of gas to oil should I use? Should I use any additives? Is the motor designed for leaded fuel (does that matter)?<br />4) I'm fairly handy - what plugs should I use? How is the timing adjusted (I have a dwell meter and timing light)? Are there any carburetor adjustments I should tinker with?<br /><br />I'm sure I'll have more questions. Thanks for all the help.<br /><br />DJG
