Marine air systems installation.
I recently purchased a used air conditioner and was wondering if anyone has any experience installing these and can tell me if theyre difficult at all, can I do one of them? Heres the link to the particular model I purchased. I got the condensor and evaporator.
http://www.eddhelmsmarineparts.com/...nits-mechanical-condensing-units-csm6-16.html
Marine Air conditioner
Never installed one before but here is some links which might help. Drilling the hole thru the bottom of the hull will be the one that gets me. If you know how the unit is installed in a boat like yours that will be more then half the battle. The other half will be do you have room for the unit, my boat has one and it is in there using a shoe horn so to speak
http://www.wrightmarine.net/5120.html
http://flagshipmarine.com/do's-don'ts.html
ericcarr2000
Ensign
My boat has two of them through the hull bottom clam shell inserts, one for the sea water pump to be able to spray down the boat and the other is there just nothing hooked up to it till now that is.
