MolsonCanadian
Thread starter- Joined
- Jul 9, 2010
- 199
I have a marine airr Air con/Heat system onboard my '90 Doral Prestancia. I purchased this boat back in July.
I've tried the A/C a couple times without success. In "Start" mode the pump runs and it seems to be moving enough water. When turned to "RUN" mode, the compressor kicks in and sounds fine.
The fan speed dial makes no change in the actual fan speed. It is constant at what I would call low/medium.
The warmer/cooler dial makes no change in the air temp.
Air temp exiting the duct is room temp.
This past week I tried it for heat, with the dial turned full "warmer". system started fine, compressor kicked in, but temps didn't change. I left it run overnight to see if it would change, but no go.
Fins are all clean, unit looks clean, compressor is hot to the touch.
Any ideers?
Any ideers?
