marine battery
Fireman431
Re: marine battery
I guess it depends on what you read and where you are reading it. Do you want the best battery or the best battery for the average price?
Optima AGM batteries have gotten the highest ratings regarding discharge rate and shock absorption according to Consumer Reports, but you are going to pay for it. They average in the $175-250 range, mayber even more at some places.
Lifeline and Sears batteries rate highest next in both service and price with both being in the $100-150 range.
After that, you're probably looking at Wal-Mart, Pep Boys, Auto Zone, etc. Plan on $75-100.
There are some other things to look at first.
1) Do you want a starting battery, a deep cycle, or a combination?
2) Are you runnning radio, lights, depth finders, GPS, amplifiers, etc?
3) Do you have an open battery box or are you limiting the battery size to a specific spot?
4) Will you be topping them/it off with a Battery Tender or relying on the engine?
In most cases, a locally purchased marine battery will work just fine as long as it's cared for. Get the largest (CCA) size you can fit with the best warranty you can find (usually up to 3 years) and make sure if secured appropriately. Check the fluid often (if it's open wet cell) and keep it topped off with distilled water when needed. Try not to drain it past the 50% mark too often as that is what kills them. If you find that you drain it often, you need dual batteries and whatever way you want to isolate them.
boaterinsd
Re: marine battery
Just wondering why Interestate batterys aren't mentioned? I ask because we have them at the shop.
Fireman431
Re: marine battery
Interstate, along with a dozen others, are what I was referring to when I said he could get a locally purchased marine battery. I have had great luck with Interstate in my road vehicles, but never had one in a boat.
He wanted the "top 3 marine batteries", so I did a Consumer Reports search on ratings and shock absorbtion for marine batteries and listed those top 2. The lion's share of batteries all seem to have fallen right in the same area with just a couple outstanding.
ezmobee
Re: marine battery
Darn near all the batteries out there are made by Exide or Johnson Controls so I wouldn't sweat the brands much.
captainzac
Re: marine battery
Walmart, Sams, Advance Auto parts, Costco are all made by Johnson Controls
Johnson Controls make Interstate Batteries
Johnson Controls owns 49% of Interstate
The Interstate branded battery is made to higher standards than the ones Johnson Controls makes for Walmart and the others
Harry
RDJuhl
Re: marine battery
Let me jump in with a related question for the "experts"...
I am looking for ways to eliminate erratic spark while starting a 1973 85HP Johnson...for a really good starting battery, is it better to get a battery which is serviceable (you can check/fill the water level), or are the maintenance free batteries just as good?
Thanks
