marine GPS
soonerborn1
Thinking about getting a gps for the boat. I only go to lakes, whats a good one to get?
I only really want one for radar and gps. Just like to know when I go to new lakes I can get back to my destination. Any suggestions would be helpfull.
Thanks.
Justin
saumon
Re: marine GPS
Some swear by Lowrance but i'll say get a Garmin. I still have an old GPSMAP 172C and it do everything i need. Being discontinued, their color entry-level chartplotter is now the GPSMAP 421 (around $400). Personally, i prefer a separate sounder instead of a split-screen combo.
NYBo
Re: marine GPS
Radar? Did you really mean sonar, as in depth sounder or fishfinder?
Boatist
Re: marine GPS
Any GPS will get you back to your starting position.
Most inland boater do not need Radar unless it is very foggy.
You need to give us a lot more information before anyone can really help you.
First do you want a GPS/Chart plotter?
Cheapest GPS units just have numbers and a range and Compass heading to steer by. Most will also have a pointer to show you the right direction.
Chart plotters also have a Map or chart and they put your Boat in the center then as you move the map moves so you can see where you are heading. These units will also have range bearing or compas heading. These units also can draw a line as you move and to get home you just follow the trail back to the launch.
After you have had it for a while you will set waypoints at the launch and at your destination.
Size. When your 18 and can read the bible on the head of a pin you can get by with a small screen. As you get older you wil want a larger brighter screen. As the screen size goes up so does the price.
Lowrance is one company where you can see some units on line. Garmin is another.
If you go to a marine store to look at units and your salesman does not start out by asking questions about you and where you boat then I would go somewhere else. You need to take your time in selecting a unit. there is a lot to learn before you should select a unit.
Hear is a tutorial that will get you started about what GPS is and how it works.
http://www.lowrance.com/en/Support/Tips-and-Tutorials/GPS-Tutorial/
http://www.lowrance.com/Products/Marine/
You can go to Lowrance's site and download an emulator like the Elite 5 then set you screen size to 1024 by 768 or larger and install. With the program you can run the unit from your PC and give it a try.
Your use your mouse to hit the buttons. Hold the power button to exit.
When you turn it on you will be in Oaklahoma so ZOOM out the use the arrow buttons to get to your area then zoom back in and you can see how it works.
http://www.lowrance.com/en/Downloads/Product-Emulators/
5150abf
Re: marine GPS
I have a Garmin and love it, the fishfinder part seems to work really well as well as the GPS and the interface is really easy to use too and it is color.
Tons of options, normally run in the split screen with half finder half gps and you can choose any of like 12 readouts to display on the same screen, I have voltage, speed and time on the split, it is really cool, it even tracks max speed, time moving, time stopped and mileage.
I think the new one of mine is a 748 or somehting like that, I have a 178c.
Boatist
Re: marine GPS
Easy to install if you just follow the directions.
If you also have a VHF Marine radio with DSC then will want to hook the GPS up to your radio also. This is a little harder but if follow the instructions in the radio and GPS manual it is pretty easy.
