Jonboat2Bassboat
- Joined
- Jul 27, 2012
- 89
I am extending the front and rear decks on an aluminium Jonboat and upgrading the aluminium sheet metal floor. These will be surfaced with marine carpeted plywood panels and screwed onto the boat as a unit with SS screws.
Been reading the repair forums here and seems there is no clear answer on using marine or exterior plywood on aluminium boats. Hopefully a few answers on what I have read will help me decide.
Have read marine plywood is treated with copper like PT plywood and should not be used on aluminium. True?
If no, marine plywood can be used but needs to be sealed. If yes, use exterior plywood but it too needs to be sealed.
If both types of plywood need to be sealed, what to seal with? Spar varnish, Polyurethane or some sort of marine epoxy?
One guy said only seal the bottom and edges of the plywood as the adhesive will stick better to the unsealed plywood and, with the marine carpeting, will provide a waterproof seal for the top.
If sealing is required, what carpet adhesive should be used? Have found several marine carpet adhesives from Henry's 663, DAP / Weldwood Contact Cement and ********* carpet adhesive but none that work with sealed plywood.
Any thoughts?
Any thoughts?
