Re: marine plywood
This has been a forum discussion many times ( some quite heated). Now the results of those discussions are that there is no doubt marine grade Douglas fir is by far the best to use (it's the only plywood I use), BUT the difference of opinions are is it really needed.
The answer is not exact...it's where opinions come in...exterior AC plywood is used often, as well as underlayment and accuraply. All are okay since it all needs to be sealed with glass when installed.
MDO is also preferred by some here, and it has many +'s too. The bottom line is how much do you want to spend vs the quality of the finished product. Personally, as I've said I stick with marine grade (straight, easy to work with, solid core, and doesn't soak
up as much resin as other types)
So, the choice is yours....good luck.
CW
Here's some reading for ya.
http://forums.iboats.com/showthread.php?t=459828
