marine stove troubleshooting
acampane
So here I am with issue number 2. I have a sea ray 250 1990. The alcohol stove on board is not working. The knobs to turn alcohol section on simply don't turn and the electric end jusat doesn't turn on. Ill be taking it out this weekend to work on it. Any ideas thanks.
Stachi
Re: marine stove troubleshooting
maybe push in on the knobs before turning them ??
rwidman
Well, it looks like you have two different problems. When did this happen and was it all of a sudden or gradual?
It would help if you would post the make and model of the stove and whether it's a pressurized or non pressurized (alcohol section) stove. The manual for the stove should explain how it's supposed to work. If you've lost it, the manufacturer may have it for download on their website.
As far as the electric part, you do know it only works on 120 volt AC shore power, not on battery power, right?
acampane
Rwidman. Yes I do know about the electrical with stove. Shore power is hooked up with breakers on. I will be at the boat Saturday and will pleat detailed info Thanks for your help
rwidman
Good. Just asking. Some folks don't know that.
