Marine Tex & fiverglass mat
superbenk
Is it possible to use Marine Tex with fiberglass mat to make sturdier patches & repairs? Probably a silly idea and more money than its worth, but I thought it might make for easier repairs of damage that's too big for straight Marine Tex but too small to want to get into a full blown fiberglass repair. The pasty Marine Tex seems like it'd be easier to work with than gooey, sticky resin.
Re: Marine Tex & fiverglass mat
Ayuh,.... No doubt, Stupid expensive, but ya it'll work,....
Just like mixin' yer own resin, 'n fillers,...
superbenk
Stupid expensive means its better, right? :D
Woodonglass
PC-11 and Marine Tex are similar products. When I was in the pool business I use Fiberglass cloth/fabric and PC-11 for patches all the time. Works great for small quick patches especially Underwater! I see no need to use it in area where you can use normal resin and glass.
Yacht Dr.
Hello superbenk ..
I would suggest at this point that you contact Marine Tex Support for your question/answer.
I dont think anyone on the forums can suggest a Proper way of adding any type of filler or glass to a product that is in use to the general public with its own standards and application data ( which you can find online ).
I would say NO. Dont Do it unless you have specific guide lines from the Manufacture of Any product.
So No ! .. you cant do it unless MT said you can. I dont think these products are made without specific application data ..
Follow the data.
YD.
Woodonglass
Hey SB,
I Went to the MT site and...
"Marine-Tex is a creamy paste consistency that can be applied on vertical or horizontal surfaces, easily fills gaps, and can be shaped to rebuild damaged components. Marine-Tex paste provides waterproof repairs that can be used with fiberglass tape or cloth to bridge holes and reinforce structural repairs as needed. "
so it appears it is like PC-11 and can be used with Glass Cloth and tape.
