Marine Tex on Alodine?
boatdude100
Repairing corrosion on stern drive. I have to build it up around trim motor with as little sanding as I can.
Question: Does anyone have experience putting Marine Tex on top of Alodine? Customer service said "you have to try it". Has anyone tried it?
I would like to follow what seems recommended- Alumiprep to etch/clean then Alodine to protect and paint over (after a primer)
I'd really like to put the Marine Tek epoxy on toop of the Alodine which would give it an anti-corrosion layer but it has been suggested here to apply on sanded down bare metal.
Anyone have experience with this? Thank you!
cptbill
Haven't tried any of those, I use JB weld for those kind of repairs
dingbat
I used JB to resurface/repair the cooling passages in a corroded aluminum block with good success.
Already bare aluminum, just cleaned the surface with denatured alcohol then applied a thin layer of epoxy where needed. Covered that with plastic wrap and used a plastic spatula to fill in the voids and remove the excess material. The wrap worked surprising well to maintain the flat surface
L
boatdude100
Anyone have experience putting epoxy (Marine Tek or JB wield) over primer at all or .. only on bare metal?
Chris1956
So you want to put a stronger material (epoxy putty) over a weaker one(primer)? I cannot imagine that is a good idea. Suppose the primer peels?
You can likely remove the primer with some acetone and a rag.
Scott06
Do Some research on automotive finishes in many cases it is recommended to put filler over an epoxy or etching primer to prevent metal corrosion. Good primers like this are not weaker. As with everything using the correct materials and prep is key.
Chris1956
You realize the filler is epoxy, right? Also, last I checked, epoxy is significantly stronger than primer.
Scott06
Not sure if you are trying to evoke a sarcastic response... You are talking about cheap primers vs something like this, which is epoxy made for direct to metal-
IF the OP blast to clean the corrosion starts with this and then can use what ever filler he wants and follows the topcoat instructions he will have an OEM like finish that will last for years
To the OP I think yo are on the right track with the alodine not sure if thats what merc does first as none of the rattle can primers seem to hold up well. I think you will have a tough time getting a manufacturer to commit and say materials they dont make will work.
Chris1956
The OP is looking to use either Marine-Tex or JB Weld. Both are epoxy fillers. I recommended that they be applied to bare, clean aluminum. Once that is done, he can prime with a self-etching primer, and paint of his choice.
I have not used the primer you have recommended, however, if you are applying epoxy filler to bare aluminum, I do not see the advantage.
boatdude100
Ok here we go. But first..
Question: would you read these manufacture instructions as applying Bonderite M-CR 1001 (print prep) to a wet surface of Bonderite C-IC 33 (aluminum cleaner)? Seems odd
THE PROCESS (According to tech bulletin below)
The process to prepare metal for painting normally consists of the following steps:
A. Cleaning (Bonderite C-IC 33)
B. Water rinsing
C. Apply BONDERITE M-CR 1001 AERO
D. Water rinsing
Technical Process Bulletins:
Scott06
B. Water rinsing
D. Water rinsing
No you rinse with water in between any residual water is no different than the water you are diluting the Alodine with. Prob biggest key if spraying is to keep it wet for process time. Then don’t let it dry before rinsing
