Because automotive starters do not sit in a closed engine compartment with a bilge full of explosive gasoline fumes.Originally posted by thmlrmg:<br /> why is that? is the marine one shielded and the auto isn't? thanks for the quick post and apparently saving my life
First thing I do, lift the engine cover take a big sniff,No smell ,then turn on battery & then blower. I must admit to not waiting 4 mins before I crank as having had the engine compartment open and had a good sniff I feel its not full of a petrol air mix.no engine box sniff test
I like that idea! I can remember to run the blower first out but often forget after sitting a while on the water. Probably the worst place to be when launching a motor cover.<br />Looks like I got a wiring project to get at...<br /><br />kudos rodbolt!wired so if the blowers are off there is no cranking the engines.
