marine vs. automotive engine
Rich Novak
I know the can and gaskets are different and the starter ect. Are marine what else is diff from a automotive engine.
Can I put a automotive engine in if I transfer the marine parts to the auto engine
Current engine has cracked block.
1972 omc 225 sterndrive electric shift.
Thanks, Rich
Thanks, Rich
Ayuh,.... Sure,.... change the core plugs to brass too,...
tpenfield
Yup, fuel and electrical systems would have to come over from the cracked engine, but the iron will be the same with the exceptions already noted.
Rich Novak
Thanks for the replys.
How does a marine can differ from automotive.
Rich
coolbri70
if you are referring to the cam shaft, it has to do with power range at rpms. boat motors run high rpms all the time where automotive engines only rev high until shifting to the next gear
tpenfield
The marine cams are 'milder' with less overlap in order to avoid/minimize reversion at idle speeds.
HT32BSX115
Rich
CAM (shaft) , right? Truck/RV camshafts closely approximate marine camshafts.......Most truck engines can successfully be "dropped" into a marine application (using the appropiate marine starter/dist/water-pump/manifolds/core-plugs etc)
