You can swap them around to see if the issue follows the coil. You can also use an ohmmeter to do a resistance test on each coil. Th primary side should be almost zero ohms and the secondary side should 800 -1100 ohms. There is also a DVA voltage test, you should get about 300 volts AC at cranking speed.
