Re: Mariner 150 - High altitude, changed jets, no go!!!
I do know the thread size is the same...in fact, to order the 6 new idle jets, and the 6 new main jets all in .060 size, they were the same exact part number form Merc. (Part #1395-6487 listed as an idle jet, they don't even list a main jet in .060)<br /><br />And no way I'm getting up on plane. It dies at idle slowly, and dies instantly if I try to throttle up. I can idle and throttle up just fine in neutral, but nothing once in gear.<br /><br />No I didn't try it out before I made the changes...in fact, I should really check a few more things as well. I replaced the fuel filter and primer bulb...that would be my luck, there would be an air leak giving me the unburned fuel smell, and killing the engine...but if that were the case, would I still be able to throttle up in neutral?
