Mariner 175 Wont Rev in Gear
badjo
Hey guys - newbie here,
I got an 88 Champion with a 175 Mariner, just replaced throttle tower and a bunch of little items.
Put the boat in the water yesterday... no leaks!!
But the motor will rev fine in neutral, put it in gear no problems, but when I start to gas it up it will go to about 2k rpm max... it then wants to stall.
I can pull the throttle back and idle around fine.
While the boat was moving I got back and manually moved the throttle body and it did the same thing ... it slowly tries to rev but then starts to stall.
If I leave it in high throttle, it will stall out.
Timing?
Anyone know where there are some online pictures of this motor so I can see if I am missing some kind of timing advance mechanism.
Hard to test this repair out of the water, and my nearest lake is an hour away.
badjo
Re: Mariner 175 Wont Rev in Gear
No replies yet but more info:
The motor will not rev past 2k rpm under a load.
New spark plugs
Jets clean and proper size
I tried manually moving the timing advance arm while under load... advance/retard only bogged.
Gas lines are clear, ball firm.
Just got shocked 6 times running the boat in a tub.. not under load but idling.
When I am in the lake and move the throttle forward in gear the RPMs do not jump around at all... only a rapid bog that will kill the engine if I leave it there for 4 to 5 seconds. No sign of life.
Any test suggestions?
