Mariner 1982 gearshift shaft
macca123
Hi
I am trying to remove my gearcase on my mariner 40hp 1982 seial no 6e9l 405360 I have the 6 bolts undone around the leg and it drops down about 1 inch thats as far as it will go, it appears the gearshift shaft is the problem where do I disconnect it from.
thanks for any replies
regards
keith
smsscuba
Re: Mariner 1982 gearshift shaft
You should find the elongated nut towards the bottom of the leg where the gearshift is joined.Loosen the nut towards the top section and the shaft should split apart.Took me a while to figure this out.....
macca123
Thankyou for the reply, Yep found it !!!
regards
keith
