Mariner 1996 Outboard 150 [L] bogs down at 2k rpm
RedWhiteAndTrue
Model 7150412ED, serial 0G407849.
Bought boat used (1994 smokercraft ultima 175) 4 years ago, had the powerhead rebuilt after scored rings (the oil injection failed and I had it removed, just running premix now for 2 seasons). Sometimes the engine bogs down and runs rough around 2k rpm, won't climb any higher... I typically have to idle it super high until the rpms get past 5k, then throttle back down and get underway. "Bogs down" as in, as I accelerate steadily (not hammer down, not baby it), it's getting overfed or starved, the fuel isn't combusting and drowning the engine. Sometimes I can feather it past the sticky point, but lately I've been slamming it past and it seems to be less of an issue. This usually happens if I don't pump out the premix and mix it up each time, and sometimes it will even if I do. I'm running 50:1 with ethanol-free octane 91 or better. I try to use full synthetic 2 stroke oil (quicksilver) whenever possible too. Putting seafoam in the premix helps but not always (1.5 oz to gall). Last time out, I leaned my mix to about 70:1, she ran the best I've seen all year... I'm hesitant to call this a win though. Am I heading for another rebuild? Need some advice.
Dukedog
do comp test first... don't run it any less tha 50 ta 1.... sounds like a carb issue.. do you have an oem manual?.. if not send me an email addy.. i'll get ya one.
Dukedog
it could but would be down on raw power.. weight and configuration (set up) would determine how it runs with low comp.. jus tired will be different from a damaged hole...
Chris1956
Running the motor with less oil will make it run real well for a very short time. After that it will have less than the required number of moving parts. Stick to 50::1 mix.
It should run just fine on premix that has been sitting. I suspect your carbs are not clean or adjusted correctly.
BrianVT
Check the simple stuff 1st.
Check fuel filter(s), check the condition of the inside the fuel lines, and check the ball valve at the quick connector.
The inside of my fuel lines was degrading. There is a clear inner liner that was falling apart. I noticed a bit of it in the fuel filter that I replaced. A bunch of this crap had built up ahead of my ball valve and restricted fuel flow. The gray fuel line is known for this.
I had the same symptoms you are experiencing. I cleaned out the connector and replaced the fuel lines. All good now.
I hope your solution is this simple/cheap.
