Mariner 200hp EFI Ventilation/Hub problem
Sotestar
I just bought this 1997 ZX200 but have been having problems with the rpms on the hole shot. After getting it up to about 3000rpm the rpms often jump very high over 6k but i let off immediately. I have the engine all the way down on the plate and tilted all the way down as well. Checked the prop and don't believe its spun because it does it about 1/3 of the time. Thought I was having cavitation/ventilation problems but Its as far as it can go in the water. After trying several times it gets up to speed just fine but sluggish on the hole shot plus I have to watch it to make sure it doesn't spike. When I am able to get it wide open it runs about 50mph @ 5200-5400rpm but speedo is inop. It has a 17" SS prop. Any help would be greatly appreciated.
Also this last time on the lake I got it started right off the trailer then cut it off after idling for about 5 minutes. I tried to start it back up and it almost sounded flooded, I cranked it several times w/ the fuel off to clear the cylinders but was never able to get it started after an hour. Got home and it started right up of course. Can a 200hp EFI flood? Any help on this problem as well?
Since I just bought it, any suggestions on what to changed besides plugs and filter as safe measures.
The guy who owned this boat prior hadn't used it for a year because he went blind, I am thinking of taking it to a shop but what should I have them look at and change other than the plugs, filter and all the fluids I have already replaced. ie. fuel bulb, check valves and bleed system?
Thanks,
Scott
Sotestar
Re: Mariner 200hp EFI Ventilation/Hub problem
FYI ....I found a small crack on my hub bushing but under load it would open up and just spin the prop.....I guess even though it was intermittent it was an easy fix...
