eatropefish
Thread starter- Joined
- Jan 9, 2007
- 24
I have a Mariner 45 hp(ser.# ob297199) bought used. When I start the engine the telltale takes approx 15-30 seconds to start flowing water. At idle the stream is weak in my estimation and the water is hot. At higher rpm the stream looks stronger. I replaced the impeller when I took ownership of the boat and every year since. As of now I don't know the pressure. Could I have a restricted power head? What are your thoughts on backflushing thru the telltale with CLR? I have not used the water hose on the supply tube yet. Thanks for your time.
