trehanejox
Thread starter- Joined
- Mar 11, 2009
- 10
Hello to all and thanks in advance for any help,
I have a mariner 50 3 cyl, 1989(I think) serial no. 9560228.
I replaced the impeller end of last season and was readying the boat for the water last weekend. Started fine but I noticed very quickly there is only a trickle of water coming from the tell tale.
Removed the bottom leg (blew the system thru with a compressor, no probs) and attached a hosepipe under v/low pressure to the pipe that carries water from the impeller.
Water is peeing quite happily thru the tell tale but also water is coming back down inside the leg and some from the exhaust holes?? I'm not familiar with the workings up there but it seems likely there must be a bad seal/grommet at the top end of the pipe. Does this make sense? Any diagrams, advice or experience with this? Just hope I dont have to remove the powerhead
Cheers, Jochen
Oh, I also found the overheat alarm wire tucked away(brown/white), when I ground it with the ignition on it beeps but where should it be connected to the engine?
Cheers, Jochen
