Mariner 55/Mercury 80 Mounting holes...
pyro225
Hi all, I'm sure most have seen i use an underpropped mercy 80 on my boat to get the speeds i need. hopefully this should be coming to an end as i have just purchased a mariner 55hp twin cylinder i think i can prop correctly to get the correct speeds (and hopefully slightly better economy).
My question is this - non have power trim so what is the likelihood the bolt holes will line up for a straight swap?
cheers
Texasmark
Do you have access to the Mariner? Can you ask someone who is with it to measure it for you?
