Mariner 60 1998 weak spark No2
Scondo
Hi All<br />I have a mariner 60 serial No op004089, giving me a hard time. it starts fine but runs like a bag of spanners,if i pull the HT lead off No 2 It does little to the running of the engine ,if i pull 1or2 HT off it boggs down.So have borrowed a known good stator and trigger and replaced on to my engine no change ,removed carbs and cleaned etc no change, borrowed a known good CDM and replace one at a time and no change ,I am lost!!Where do i go from here please<br />Thanx
Scondo
Re: Mariner 60 1998 weak spark No2
Hi All<br />Where i say if i pull 1-2 HT off it boggs i ment 1-3 HT
Scondo
Have put new plgs in and changed over no change. i did a compretion test today and no copression in No 2.from here not sure ,need to maybe look at reeds.
Laddies
Banned
Mers, with no compression you have more problems than reeds
Scondo
Hi Laddies<br />Thanx ,i took ogg the induction plate and saw two nice grooves down the bore on No 2 cylinder so that tells the story right there. will start to strip down and then put back new then go out fishing to forget.
