Mariner 60 4stroke midrange missfire
gohagan
I am in Ireland and have a twin engined R.I.B with a pair of 2001 mariner 60 4strokes fitted,The stbd engine has developed a missfire from about 2500rpm,I have swapped the carb bank over from the other engine thereby eliminating all possible other causes.The fault followed the offending carbs to the other engine. I have cleaned each individual carb,rebuilt,and synchronised the bank and tried the engine again on 2 occasions with no great success.Can any one offer any inspiration as to where on which carb the fault may lie? Thanks
JB
Re: Mariner 60 4stroke midrange missfire
Moving to Mariner troubles.
BillP
Pull the plugs and see which is wet or looks different from the others. Sounds like a plugged jet to me.
hondon
Those carbs are really difficult to clean completely.Your best bet is ultrasonic cleaning.No carb dips or you will cause more harm than good.
gohagan
Thanks for the help. I swapped out the carbs till i found the offending one . Then after stripping down the unit found a very small jet which seemed to be blocked.I rebuilt the carb and installed the bank of carbs, synchronised them and all is now well!!!!!
