mariner 60
tsp
I have a 1986 mariner 60 3 cyl which used to be difficult to start and I suspected was running too hot especially on the top cyl. I had it checked by two different outboard mechanics both said there was nothing wrong with it.<br />Last time I took it out I limped back on two clyinders and after stripping it down discovered a slightly melted top piston. <br /><br />I have rebuilt the motor and have good equal compression on all clyinders. Also discovered the water temperature sender and warning buzzer was not working. I have replaced these. I also have rebuilt the water pump and the fuel pump.<br /><br />Problem now is it wont start. Battery is good. All coils are working fine and good spark to all spark plugs which are all ok. If I inject some fuel into the cylinders the engine will fire and gives a slight backfire into the exhaust if I keep cranking. <br /><br />I suspect that I have done something to the timing but as I do not have a timing light I cannot check exactly where the no 1 cylinder is currently firing. <br /><br />The manual that I have gives a timing of 22degrees BTDC on wide open throttle with the engine in gear. I cannot of course check this out.<br /><br />Any ideas. I am reluctant to take the motor back to the outboard mechanics.
petryshyn
Re: mariner 60
Is it possible that you mixed up the trigger leads, charge or coil leads at the pack?
Kuni
Re: mariner 60
HI <br />DID YOU DETERMINE WHAT KILLED YOUR TOP CYLINDER THE 1ST TIME?<br />MELTED PISTON YOU SAID IS THIS DUE TO NO LUBRICATION OR DID THE TOP SEAL LEAK AND SHE LEANED RIGHT OUT.?<br />YOU MAYBE DEALING WITH THE SAME FAULT<br />IT DOES SOUND LIKE YOU HAVE UPSET THE TIMING THOUGH MAKE SURE YOU HAVE TIMING RIGHT THE LEAD COLOURS IM NOT TO SURE OF ASK DARGAVILLE MARINE(WHANGAREI) TO PHOTO COPIE THE RELAVENT PAGE OUT OF A SHOP MANUAL FOR YOU IF NOT TAKE YOUR BOAT TO NORTHLAND BOATING IN DARGAVILLE AND THEY HELP YOU.<br />GOOD LUCK
