Hello all, I have a 17' Mark Fisher Marsh Hawk 3V with a 75HP Mariner OB. I'm planning on a trip down to Smith Mountain Lake next month, so I took the boat out on the river and noticed that the Tach is not working and the volts remain around 12.6V at all times. As I rev the motor, the volts do not change. I have a volt meter in the dash and the fish finder also can display volts.
I understand that this was a common problem with the Mariner OB in my range of year. Also I was told that usually if the rectifier is bad, that stator will follow. I've had the boat four years now (bought from original owner) and it been on the water about 4 times, and the Tach never worked.
Is this something that a person can repair with some mechanical knowledge? How do I test the stator or is there an easier way to tell if it went bad, without taking everything apart?
The motor starts without a problem, always on charger, and runs as if its new. I do not want to screw anything up since it runs so well!
Is the rectifier on top of the motor, silver box with two red wires, two yellow wires and a grey wire?
Also I guess there are two rectifiers for this motor, a 9 amp and a 16 amp? How can I determine which one I have? There are these numbers on the size of that silver box (815279 1 with 2590 underneath of them)
Also I believe I have a 1991 Mariner. Serial # 0D037684. Its a 3 cylinder with oil injection and electric start.
The dealer price the part at $150-170, but I've seen them on ebay between $65-$135. Anyone recommend somewhere that a fair price and reliable?
Thanks for any help in advance!!
Jeff
Jeff
