Re: Mariner 75HP Rectifier?
Sorry I can't help you with the tach voltage but from what I understand a bad stator can effect your tachometer. Not sure if your ground wire would effect your readings on your stator; if it would your readings most likely be lower than what your have now. It almost sounds like some of the insulation on the windings may have melted and shorted your windings therefore reducing your voltage. I just had my AC/DC circuits course in computer science, paying off already. hehehehe. Have you asked your local boat shop if they can test your rectifer if you bring just that in? Hate for you to waste money on something you can repair yourself. Hate it even more when a man's fishing trip is sidelined. Bin there, done that and darn sure didn't like it either.
I really appreciate the help everyone. The black wire that is broken is definitely connected to another terminal.
I had continuity with the two yellow wires from the stator, but none when each was grounded. The resistance, if was done correctly, was .001-.05. Specs call for .19-1.7
I have someone coming over later in the week that knows a lot more about motors and does side jobs, to help. I'm just wondering now that if it is the stator or trigger, not sure what wires go to what, instead of the rectifier. Unless the broken wire fried the rectifier??
I remember getting voltage from the gray tach wire, around 7.5-8v at idle.
I'll keep ya updated and hopefully I can get it done before I leave for fishing week!
Jeff
