Saltyfishnchips
Thread starter- Joined
- Mar 13, 2010
- 3
Hi all ! Just purchased a boat and motor from storage . It has a mariner 9.9 4 stroke . I have owned many 2 stroke but never a 4 . The motor hadnt been ran since last summer and the owner had said it ran but not quite right . So I brought it home with a dry tank and line . I put 2 gallons of gas in and a half can of sea foam . I was suprised to find no choke . I primed to a firm bulb and gave some pulls . After six pulls it fired ,ran for a bit then stalled .(Lower unit in a large vat of water ) Started on first or second pull after that . I would let it idle for abit then attempt to engage it into gear . Each time it would stall out . I gave up for the night and the next day tried again . Doing a very slow turn of the handle to engage I could keep it going but when I tried a higher rpm it would stall . I noticed that the idle would start out higher rpm and decrease as it warmed . Is this how this motor should idle ? Also any one know why it is stalling at higher thottle ? Last question . What is the green light next to the pull rope for ? Thanks for help
