Mariner 90HP two-stroke 2001 mod. Things I should know about these?
GreedyMuffin
Hi!
I bought a 90HP two stroke from 01 yesterday, Will pick it up within a few weeks.
The ad (Norwegian though, but the pictures are there: http://m.finn.no/boat/motor/ad.html?finnkode=84222963&ref=conversation&fks=84222963). It looks really clean and seems like it's in good condition. It has been on a service this year as well.
Is there something I should know about these engines? Seems like the normal compression is around 110-130 on these. I will check the gear oil and compression when I'm out there. It's a 5 hours drive, and I'm 17, so my father will drive when he gets back from work. Is there anything else I should check?
These engines seems really solid, and it will rock my 15.5ft boat good. (It got a 6.4 ft width).
Only downside I know of is that these is thirsty on top RPM. I will cruise in 20-24 knots, and max speed is probably around 35-38 with this setup. So I guessing that I got alot of horespower to my disposal. Giving me great speed at only 3000-3500 RPM.
roscoe
They are good motors.
Confirm water pump and oil blender are working.
And check for saltwater use/damage.
Happy boating.
GreedyMuffin
Hi!
Thank you! From what I can tell from the pictures it dosen't seem like the engine is used in saltwater, at least not much.
Happy boating to you too!
GreedyMuffin
Hi!
Comp. Was 7.5 on all cylinders, is that low?
Engine is starting right up when just turning the key, so I believe that is in good condition.
None/little saltwater damage.
Should I remove the oil injection and just pre-mix the gas?
Faztbullet
The bottom driven oil pumps rarely fail, that why there is no sensors other than oil tank level on these engines...
