Lubosleftboot
- Joined
- Feb 26, 2006
- 208
Hi Guys
Recently acquired a mariner 8 hp 2 cyl 2 cycle engine of around 1982 vintage that is virtually identical to the yamaha 8b engine of the same vintage and I have an irksome problem.
This engine will start and run for about 30 secs then it dies and refuses to start. I have checked the points and timing and they are ok in that there is a nice fat spark white in colour so I know that the charging coil is working. I have also cleaned all the wire connections and earthing points for the coils and isolated the kill switch so I am pretty sure its not the ignition system thats the culprit but I am more than willing to listen to any suggestions on the ignition system as there may be something I have overlooked.
I have also removed and cleaned the carburetor and there is fuel present in the bowl and the jets seemed clean to me in that after removal I could see clearly through the jets apertures. The fuel bulb primes as it should so I am at a loss as to why this motor will only run for 30 secs.
Compression is also excellent in both cylinders.
Can condensers cause this type of fault? Or is this a fueling problem? All suggestions are appreciated guys
LLB
Engine serial number 8M 677-370218
LLB
