Mark 30 lower unit back lash
phole440
Just need to know if any of you guys know what the back lash spec if any is for the lower unit. Have two complete units one with bad housing one with bad gears. THe two of them will make one good one.
Laddies
Banned
Re: Mark 30 lower unit back lash
Keep the shims with the units they came out of and you should be right on the money, you are actual shimming the unit to fit the gears (the gears and brgs. are + or - .001 the differance is in the hsgs.) so the shims go with the hsg. not the gears--Bob
phole440
Really is there any kind of a actual spec to measure? Paul
Laddies
Banned
Fwd is .003 to .005 backlash, prop shaft is .015 end play and Rev .003 to .005 back lash. Most places overcomplicate the shiming process for obivous reasons--Bob
phole440
Thanks if i have any problems when i start assembly you will here form me. Paul
