Master Cylinder Rebuild?
mippel
Hello,
Currently I have a leaky master cylinder for my Tie Down 70lp actuator. I was going to replace it, but the prices on line range from 80 - 120. All of the ones i can find are at the higher end of the price range. So until they get back in stock at the more affordable places (about a month) i was going to see if they can be rebuilt. Has any one rebuilt one? Are they able to be rebuilt? Or is there anything that can tighten up on the rod end of the master cylinder? This is the one I am asking about.
http://www.trailerpartsexpress.com/image/cache/47267-500x500.jpg
Thanks in advance.
SingleShot
Re: Master Cylinder Rebuild?
Yes they can depending. I put replaced the drum brakes with disc and had to replace the O ring on the dampner due to leaking, after removing the check valve. If more parts are needed you may be able to order them from Champion trailers. Here is pdf of m66 which is what I had.
  • Sb66 act 5.pdf
