Re: Math question about engine cylinder volume/pressure
The specific heat of the air is what all the previous calculations don't take into account. And that is definitley not splitting hairs. As a mechanical engineer, I am surprised you didn't mention this. Forget your thermodynamics?
As a scuba diver you also know that when tanks are filled, they are put into a tank of water. This is removing all the heat added to the air during the compression process. If you don't do this, as the air cools the pressure would drop causing a low fill.
No, I haven't forgotten my thermo....I have nightmares about that class
....I'm not discounting the fact that there is heat generated by the work being done. It definitely is part of the physics involved. However, I do not believe it would add enough heat to cause the calculated pressure to be off by some order of magnitude....The cylinder is a very small volume and the compression happens very quickly. I just don't think the assumptions made in the calc. would cause the results to be off by more than a few percent....a couple of psi maybe. I'm not curious enough to blow the dust off the thermo book to figure it out though
...Just saw your 180 psi...big difference from 115.....may have to rethink this....hmmm. I don't have any idea what the compression numbers should be on a dirt bike! I'd much rather just look it up in a service manual....I'm lazy
....We also assumed dry air for the record....air has water in it...just sayin. I mean, how far do we want to take this.....
There's a big difference between the scuba tank analogy and a small cylinder. A scuba tank is a much larger volume and the pressures are 30 times greater. With the cylinder, your talking a delta P of 100+ psi, with a scuba tank you're talking about a delta P of 3000 psi. Much more work being done to compress a much larger volume of air to a much higher pressure. That translates into a much larger amount of heat being generated. Wouldn't you agree?
I'd like to know if the compression was actually measured by the OP....what was it? Now I need to know...I'm being tortured!
