nathanhooper
Thread starter- Joined
- Apr 21, 2010
- 176
This is not technically about a boat motor, more so the boat, but it does involve motor issues, so I am not sure where to post this. But here is a question I hope someone can solve for me.
I have a short shaft motor I want to put on a boat. It is a 50hp one and I have not been able to find a boat to put it on. Well I think I found one, it has the high transom sides that then come down to a low point where the motor mounts. It currently has a 35hp on it, so I know its rated for that much, I would assume.
The problem is I cannot find any documentation on it. It does have the model number, but no max hp rating. According to the model, it can accept up to a 80hp, but if you add one little letter to the end of the model number then it is only rated for 40hp, that is according to the records here at iboats.
So my question is, if it is indeed only rated for a 40, how would I know that for sure? And, if the transom is strong, would putting the 50hp on there cause some major issues right off the bat, or is it something that would be bad in the long run.
For instance, could I put the 50hp on there, and if it floats all right and everything like that, is it safe to use? I guess the bigger question is how do they come up with the max hp listing to begin with? I hope this makes sense, and you understand my question. thanks
