Re: Max RPMs for '95 Merc XRi 150
Hi, I think the optimum/recommended top end range is 5100 to 5500 rpm with a load (prop in the water).. Boat resistance and prop choice will usually determine your top revs. Without a load to keep the engine tight the rpm will probably keep increasing until it does blow. To compare performance with another motor I think you need a dynomometer so you can have a known load factor. Hope this helps.
