Max Throttle on 1995 Evinrude E150 GLEOM
WhatsUpDoc
Sometime back I asked a question about a homemade pontoon boat that somebody where I live made. As stated in previous post the person who created the pontoon created these square/rectangle toons. Well I took all the advice here and found some good used toons for $500 and I just recently switched them out myself. I love LIVE OAKS they make great hangers for pontoon top/floor.
Well before I switched out the toons, I installed an Evinrude 150HP on it to see if it would get those square/rectangle toons on plane with zero luck. I don't think a 500hp would have done the job neither.
Well I decided to keep the Evinrude 150hp on there as it runs great but IMHO its just too fast for me. I only wanted to get up to maybe 25mph max, not 40-50MPH.
This motor is a V6 and has the power packs on it with the advance timing at the top. All I know about this motor is how to rebuild the carbs which I already did, the wiring and start it.
I looked and don't see a screw anywhere that limits my max throttle. Am I missing it or is this one of those motors you cannot limit the max throttle and have to do it manually? I'm a Mercury and Yamaha person, I can tell you anything about them but Evinrude I am new to even though I've been dealing with outboards since 1996.
Thanks in advance. If you need photos I can upload some.
Crosbyman
well in theory OB's are meant to be and like to be run like wild horses.
it helps reach proper temperature, burn fuel properly and spitt out exhaust carbon gunk that can develop and accumulate overtime.
if you plan on limiting the top RPMs to just slow down you may be creating a problem.
my understanding anyway.
Faztbullet
You could probably limit the butterfly valves from opening all the way.
Not a good idea as spark is at max advance and will create a lean burn.
saltchuckmatt
Limiting the throttle box is probably a better idea.... and limiting full throttle is rarely asked.
Growing up, we always went full throttle and then backed it off some which always helped with fuel consumption.
Chris1956
Honorary Supreme Mariner
Gee, most 'toons of about 24 feet only go 22mph with 150HP OBs on them. What kind of 'toon do you have that will go 40-50MPH?
Chris1956
Those super-fast 'toons have hundreds of HP in their engines. A single 150HP motor will not push the average 24' 'toon any more than 25 mph, in my experience.
tphoyt
Just curious why not just pull back of the controls?
Or are you trying to prevent others from going to fast?
cyclops222
I love high power boats in a need to get back to the dock fast. Otherwise I am on a full plane at about 3000 rpms.
Faztbullet
My 1998 Lowes 24' with 1981 150 V-6 will run 31-34 mph all day
