jigngrub
- Joined
- Mar 19, 2011
- 8,155
I didn't realize you were including the price of a motor in your $2,000.
I'm just wondering the cost that others have spent to replace their floor and stringers. Seems like every time someone on here posts that they are looking at a boat or are getting a boat, everyone is like....Oh gosh, you better make sure the stringers are ok or else!!!! Realistically, it isn't that huge of a job and if you are careful with where you buy your supplies, it isn't all that expensive. So, a "free boat" + the cost to put new stringers in yourself can still = an inexpensive way onto the water plus a new found hobby.
When you restore a boat, you get a like new boat for a small fraction of the cost of a new boat.
With that being said, boat restoration is pretty expensive and you can eat up $2K in a hurry... without a motor!
Polyester resin ranges between $25-$60 per gallon depending on where and how much you buy.
1708 biaxial cloth is $6.50-$9 a yard depending on how much and where you buy it.
Plywood is $50-$100 a sheet.
... and the money doesn't stop there. You'll need to buy tool and expendables (brushes, rollers, sand paper, saw blades and stuff like that). Personal protective equipment. Most restorations require painting and all the supplies that go with it. Carpet and other finishes are expensive too.... and the list goes on. If you go with epoxy resin, the price doubles.
Just as a for instance, we have a member in the resto forum that has used 42 gallons of polyester resin on his bass boat resto and he doesn't even have the deck in yet. That's $1050 in resin alone, while this is excessive (I think he's drinking it) 20-25 gallons for a 18-20 bow rider is common.
But even at $2-$4K for a resto, you still get a heck of a deal... just go look at new boat prices.
Edited to add:
Any f'glass boat over 10 yrs. old that hasn't been kept garaged or religiously covered is a candidate for rot regardless of outside appearances.
Take a look at this 15 yr. old boat:
http://forums.iboats.com/forum/boat...nature-deck-and-stringer-restoration?t=510077
Looks sweet on the outside, but look through the thread and see what the guts looked like when it was opened up.
... and you can bet your sweet bippy that if an older f'glass boat looks weathered on the outside, the guts will be even worse.
