- Joined
- Mar 8, 2009
- 44,448
More info on 1st Mate
If engines are killed from MOB they can be restarted after 6 seconds.
Was wondering about that because all the manual list is idle and neutral. Might need more then idle to go back and pick someone up
Need to have access to hub
I mounted it behind the helm which would need to dismantle the helm to get back at it. It has a button that may need to be pressed to allow motors to restart (resets MOB).
MOB and NEMA 2000
If MOB happens the location is pinned on your phone. If selected it will send messages to anyone which has been selected with location info. There is not a direct function between Hub and Chart plotter or other, but there may be new functions added in the future software updates.
Theft Deterrent
If turned ON and fob is not onboard. Manual list RPM is limited to idle
Contacted 1st Mate and asked can engines be started if TDS is ON and after a MOB event. There is not a idle limit except for first start and "disable engine start" has not been turned ON
MOB and NEMA 2000
Theft Deterrent
