Re: Maybe the dumbest outdrive question ever
I seriously doubt you have an Alpha I Gen II outdrive on a 2006 320HP engine. Since Merc has a 300 hp max on the Alphas. NOW, assuming you have a Bravo I or even a Bravo II single prop outdrive, it's still going to be expensive. The SS dual props alone are around 1500 bucks. then a new lower unit is expensive compared to the props. Usually you can find a new Bravo III lower for around $5500
Now, if you actually have an Alpha I Gen II, you would have to replace EVERYTHING but the engine. Transom shield, and outdrive.
Now, you are getting into big bucks, and a lot of work. Way over you 2K limit.
