I screwed up! I recently purchased the MBS gimbal bearing installer and alignment tool. I didn’t see the instructions as they were stuck to the inside of the box. Bottom line is, I pulled my old gimbal bearing before obtaining the measurement in order to drill the hole for the installation driver. I have a 2007 boat, purchased it new and everything is original. So, seeing as how I would think all alpha one gen II drives should be the same. Has anyone used this tool on that drive and if so, can they send me the measurement of where the hole should be drilled? If anyone has any other suggestions, it would greatly appreciated.
