I replaced the old pre-alpha housing on the transom with an Alpha-1 Gen 1 gimbal housing/transom plate last year. When I did, I had to use the Alpha 1 trim hoses (larger dia.) instead of the existing trim hose (smaller dia.) because my existing braided hoses would not mate to the housing due to the size of the fittings. I used my existing trim pistons, as they were just rebuilt. I did not change the trim pump.
My trim has not worked since. The trim motor runs and the drive will move very slightly, but will not go up all the way. the drive needs a little coaxing to go down. The pump is connected correctly electrically and the pump runs. Fluid is full, and no air in the system.
Could the trim hoses from the pump to the housing be my problem? If so, I would imagine I will have to change my trim pump? If so, would I have to change the trim pistons too?
I've got the motor out now, so everything is easily accessible and would like to have everything in proper working order.
