Richmond2000
- Joined
- Aug 18, 2015
- 62
first I did search the forum ...
I have a 1969 MC - 1 mercruiser I/O 120 HP 2.5L GM powered and was wondering if a Alpha one lower unit will fit and OR the whole out drive to the bell housing
my upper case is in good visual condition but my lower is quite nicked and I am expecting 300-400 to weld it up and Alpha ones can be had for that money around here also my unit needs resealing + ??? and only grinds going in to reverse
my research makes it look like a Alpha 1 lower will fit back to 67 OR 72 depending on which seller is listing it on iboats out drive sales links
they also list the whole unit fitting with drive shaft change over
thirdly is a Alpha 1 lower any better?
my MC 1 is power TILT NOT trim and has the second set of shocks AND the locking knob on the side of the upper unit
