Re: Mc-1 Crack near Prop
That crack is caused by corrosion under the bearing carrier cover nut. It's not completely fatal, but it will keep getting worse, eventually leading to the lower leaking oil. It's an MC-1 drive, and as long as it's 1970 (not 1969) then an SEI lower should fit on. What the drive serial number?
EDIT: I see your signature uses the word 'replica'. Is this future boat being built by the same person who built the original? Because that is the only way it can be a replica, otherwise it's an exact copy, but not a replica.
